It is currently Sat Jul 19, 2025 12:00 am
PostPosted: Thu Sep 13, 2007 8:07 am
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
Does anyone know of any nice, generally available material that could be used as a laminate between wood layers in solid bodies?
I need a black veneer about the thickness of poster board.
LMII sells the fiber veneer, but it is quite expensive...RCTonewoods is much more reasonable, and I am about to get some stuff from him, but I wanted to see what others have done first...
Stephen
www.ziegenfussguitars.com
PostPosted: Thu Sep 13, 2007 12:50 pm
I bought black dyed veneer, but it is .027 thick. I use it sometimes on rosettes and what have you. I also bought some maple veneer that I use the same way, making a BWB strip for various things.
I also purchased some of the black and white fiber from Uncle Bob at RCTonewoods. You wont be unhappy with anything you get from Bob. It's all top notch stuff!
PostPosted: Thu Sep 13, 2007 1:17 pm
Steve I have some of Bobs black and white fiber, you can check it out tomorrow.
PostPosted: Thu Sep 13, 2007 1:58 pm
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Zip/Postal Code: V0R 1K1
I have purchsed Veneer and Super-Soft 2 here
It's an interesting site to visit.
Kind of like buying Tonewood.  You see the piece of veneer you buy.
Rick Hubka
Rick Hubka
Chemainus BC Canada
PostPosted: Thu Sep 13, 2007 11:05 pm
First name: Stephen
City: Jackson
Thanks so much for the suggestions...
PostPosted: Fri Sep 14, 2007 12:14 am
How about carbon fiber cloth and West Systems epoxy? I've used both the cloth, and the mat between laminations and it makes a nice accent line as well as adding stiffness.
PostPosted: Fri Sep 14, 2007 1:03 am
First name: Stephen
City: Jackson
Yeah,
I build and design boats for work, so I have tossed this around quite a bit...I haven't brought myself to the point where I can add composites to wood - but that is only because of me....I have no idea of its affect on the dynamics of the body..
PostPosted: Fri Sep 14, 2007 1:14 am
I wouldn't add epoxy graphite unless there was a structural reason to do so. An exposed laminate of this material is a lot harder than the surrounding wood which makes shaping and sanding much more difficult. It is difficult not to end up with a slightly protruding surface where the material is exposed.
PostPosted: Fri Sep 14, 2007 3:20 am
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
[QUOTE=BarryDaniels]exposed laminate of this material is a lot harder than the surrounding wood[/QUOTE]
Yup...  One of my favorite Japanese saws now has many broken teeth from trying to cut cured bi-directional carbon fiber.  Depending on the epoxy used, CF cuts beautiful with a utility knife blade when it is about 60-70% cured.  But when 100% curred the bi-directional stuff I had cut like steel.
Rick Hubka
Chemainus BC Canada
